I am doing an analysis of a plate where i am applying a force of 20N from top and on the base a pressure of 1MPa. i have extracted 2-d faces(as component) and applying pressure to it.
i created a Load collector (Pressure+force with cardimage LOAD) and linked pressure and force to it. Later in loadstep, i linked it to LOAD subcase.
is it the correct way of doing this ? if not, then please guide.
At the end i am getting following error.
