I want to transfer Displacements from a model to a submodel.
I used 'fields' to Import the .op2 file and then Realization to create SPCD's (one for the Displacement(x,y,z) and one for the Rotation(x,y,z)). I used the Card Image SPCADD to combine both.
Then i created SPC load collector for all six DOF at the nodes where the SPCD's are.
Then i created a load Step and put at subcase Definition SPC to SPC and SPCD to LOAD.
If i start calculation i get the error: '* ERROR # 1908 *** Case Control data LOAD=4 is not referenced by any bulk data relevant for used subcase type.' (LOAD 4 is the SPCADD load collector)
So is it not possible to Combine SPCD's with SPCADD?
How can I do it instead?
If it helps i can upload the file?
