RUN KILLED : TOTAL MASS ERROR LIMIT REACHED
Dear Sir,
Our Model having zero error but still it is terminating after 3 minutes,
ROOT: ROLL RESTART: 0001
NUMBER OF HMPP PROCESSES 1
27/04/2018
MESSAGE ID : 207
** RUN KILLED : TOTAL MASS ERROR LIMIT REACHED
NC= 0 T= 0.0000E+00 DT= 7.8229E-19 ERR= 0.0% DM/M= Infinity
ANIMATION FILE: ROLLA001 WRITTEN
** CPU USER TIME **
#PROC CONT.SORT CONT. F ELEMENT KIN.COND. INTEGR. I/O TASK0 ASSEMB. RESOL
1 .1562E-01 .0000E+00 .1047E+01 .1250E+00 .4688E-01 .1938E+01 .0000E+00 .6250E-01 .3766E+01
** CUMULATIVE CPU TIME SUMMARY **
CONTACT SORTING............: .1562E-01 0.41 %
CONTACT FORCES.............: .0000E+00 0.00 %
ELEMENT FORCES.............: .1047E+01 27.80 %
KINEMATIC COND.............: .1250E+00 3.32 %
INTEGRATION................: .4688E-01 1.24 %
ASSEMBLING.................: .6250E-01 1.66 %
OTHERS (including I/O).....: .2469E+01 65.56 %
TOTAL......................: .3766E+01 100.00 %
** MEMORY USAGE STATISTICS **
TOTAL MEMORY USED .........................: 3352 MB
MAXIMUM MEMORY PER PROCESSOR...............: 3352 MB
MINIMUM MEMORY PER PROCESSOR...............: 3352 MB
AVERAGE MEMORY PER PROCESSOR...............: 3352 MB
** DISK USAGE STATISTICS **
TOTAL DISK SPACE USED .....................: 137246 KB
ANIMATION/TH/OUTP SIZE ....................: 137246 KB
RESTART FILE SIZE .........................: 0 KB
ELAPSED TIME = 8.11 s
0:00:08
NORMAL TERMINATION
USER BREAK
TOTAL NUMBER OF CYCLES : 1
==== End of solver screen output ====
==== Job completed ====
Here by I have attached .out file and images of related this issue, I request you to go through that & notice us where we are doing mistakes
If you review the out file we can see that the time step is very less in this model (e-19) and mass was added to maintain the imposed time step which resulted in run termination.
Better I suggest you to remove /DT/NODA/CST from the engine file, run the analysis for a few cycles and find what is causing for this time step drop.
From the engine out files check what is causing this issue. It could be an element, or node or interface.
For an element, check the related material.There must not be an error in the units system that this data is given in. check the element size also.
For a node, check the characteristics of connected elements. If the node is on the master side or the slave side of an interface, this interface must be verified.
For an interface, the gap of the interface must be verified if some failure happens on the master or the slave side of the interface. Also check the interface for any penetrations and if any are found depenetrate them all.
