i have downloaded the model file of a wing for certification of optistruct analysis and since it was instructed to run . when i run i got the error shown in screenshot below. what changes should be done?
Hi @vishwask
Can you please this solver file instead?
The file is updated and available online.
Thank you for helping. in 2017 student edition, when i opened the hyperview after running , the session and results tab are not displaying on left side of the page. how can i enable it?
@vishwask
Go to View browsers>> HyperWorks and select session to get sessions tab
similarly, go to HyperView and select results tab.
@vishwask Go to View browsers>> HyperWorks and select session to get sessions tab similarly, go to HyperView and select results tab.
Thank You for helping. I just want to know if there is an tutorial that explains basics of handling hyperworks including tools,parameters etc. Thanks in advance.
Could you please explain what you mean by parameters and tools?
not exactly tools but parameters. for examples like for control cards there are different options but i dont know the significance of those. Same case like when u r introduced to new software and what is significance of each tab or function and when it is used. Since i dont know much about hyperworks, i wanted to know if there is an tutorial that helps me go throughout the software
As you go on learning you will get introduced to cards, parameters etc... this is a way to start with.
If you want to more information about cards used and some theory, you can refer to the OptiStruct user guide and reference manual.
