Hello everyone,
I want to do a prestress modal analysis? However, I don't know how to set up the case. Is there any example? Thank you
Best Wishes
Roy
Hi @Roy Duan
Yes, you can perform PreTension Modal analysis through HM-OptiStruct using STATSUB (PRELOAD) case control command.
You need to create two load steps, the first step can be Linear Static analysis
In the second load step which is Normal modes, pick the previous Linear Static analysis under STATSUB(PRELOAD) as shown below:
SUBCASE 1 ANALYSIS = STATICSSUBCASE 2 ANALYSIS = MODES STATSUB(PRELOAD) = 1 SPC = 2 METHOD = 3
