I'm getting this error:
A fatal error has occurred during computations:
*** ERROR # 312 ***
In static load case 1
the compliance is negative or large 1.33184e+018.
Optimization/buckling analysis cannot be performed.
due to possible rigid body mode.
INFEASIBLE DESIGN (AT LEAST ONE CONSTRAINT VIOLATED).
I'm thinking is a problem of units, but I have controlled very carefully all units.
I've used: tonne, mm, N, Nmm, MPa in all steps.
Thanks in advance for your time and help!
apprada
