I have set of components like
led_high_1
led_high_2
led_high_3
etc...
i have to make a duplicate set of components
with name like
led_high_xxx_1
led_high_xxx_2
led_high_xxx_3
i need a tcl script for this in hypermesh
Try this code:
Set of component in 'led' assembly
I have to duplicate components in same assembly like I told you for set of components.
Give me the code exactly.
I didn't understand above code.
What you need to do is:
- make a loop, with each component name in 'led' assembly => use above code to create a new comp (led_high_xxx_..) and copy elems from old comp to new comp.
- move all new comps to 'led' assembly
