Hi! Radioss give me that error, can someone tell me what does it mean?
there’s a solution? The analysis doesn’t start..
thanks
In RADIOSS solver manager remove any commands from the run command field, and run the analysis.
@Baro
I see you have used -both twice in RADIOSS command field,
remove the same and use only -both and check if that helps.
what can I do ? Also i have this problem.
Please share the complete .out file.
@Baro I see you have used -both twice in RADIOSS command field, remove the same and use only -both and check if that helps.
I have remove one -both from RADIOSS command field but I am still facing the same issue
@Vaibhav Pande
command line arguments have to be exact and the syntax correct. Otherwise, the run will not start.
The name of file should be proper means the 'space' between the words is not permissible use 'underscore (_)' between the words. By using underscore the analysis will run.
