Hello everyone,
I am currently simulating an entire truck assembly in a wind tunnel environment using the AcuConsole pre processor and AcuSolve solver. I have around three porous mediums in my model along with 18 axial fans (Rotating reference frames) which has blown up the overall element size and also the complexity of the model.
When I try to run the model setup in AcuSolve, after the domain has been decomposed, I get the following errors:
acuRun: Run acuSolve ...
acuRun: set KMP_AFFINITY=scatter
acuRun: set MP_SET_NUMTHREADS=72
acuRun: set OMP_NUM_THREADS=72
acuRun: set OMP_DYNAMIC=FALSE
acuRun: set MPC_GANG=OFF
acuRun: 'C:/Program Files/Altair/2017/acusolve/win64/bin/acuSolve'.exe -np 1 -nt 72
acuSolve: AcuSolve checked out license from HyperWorks
acuSolve: *** ASSERTION in Function <memAlloc> File <mem.c> Line <129>
acuSolve: *** Unable to allocate <290044352> bytes; already allocated <73318612992>; from file <topSd.c> line <1451>
acuRun: *** ERROR: error occurred executing acuSolve'
acuRun: Wed Apr 4 16:07:48 2018
I have tried to change the mesh size and restart my computer but nothing seems to fix this issue. Could anyone provide more insight into this issue? I am also attaching the log file for reference.
From what I can understand, it looks like a problem with my workstation not having sufficient memory to run the analysis. I am running it on a 36 Core (72 logical processors), 64 GB machine.
Thanks,
Yatish
