Mark contact surfaces
Hey,
is it possible to turn off the mark trough option, if i pick nodes for contact surfaces in HyperCrash? I mean that i just mark (if i pick the nodes from the graphic) the surrface of my object and not additionally the backside of it.
Thanks for your help
Best,
Max
Hi Max,
I don't think that we have an option to turn off this. Instead, while choosing nodes, select Add/Remove nodes by picking selection option and choose one node from the required face of the model and click on expand option which can be seen in the right bottom of the graphics window. The nodes only in the face will be selected then.
0 -
I solved it /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> Thank you very much!
