I'm looking for design a structure with oval section; I noticed, however, that in Optistruct isn't the possibility to use a oval beam section. What Could I do? There is a method to import the new section or to make it?
Thanks
You can create (simple) section with HyperBeam Sketcher. Have a look at
'Example: Creating Shell and Sollid Sections using the HyperBeam Sketcher'
Thanks for reply; Unfortunately I can't find the example; can you send me the link?
Within your Hypermesh session, press 'h' to go to Help.
