I wanted to import a solver deck to HyperCrash but not all elements of the biggest part were loaded (red circle in pic). Is there a limitation for element numbers or have i done something wrong.
If you are using student edition.Then it is the limitation.It will work fine in full version.Latest edition(14.0) of Student edition we have increased limitation on node.
