I got the error #4079 which cannot figure out.
Attached herewith the test document.
One is something related to 'Time step limit' and the other one is 'Non-convergent nonlinear iterations for subcase'.
Request to suggest the solution.
Hi Sachin,
Please let us know if the error pops up as soon as the run starts or it runs for few iterations and gives out this error?
if this is the case, please consider reducing the load for the subcase and run the model again.
Please note: If you are a commercial customer, you can contact your local support for a quicker solution @ http://www.altairhyp...ortProduct.aspx
Thank you sir, for suggesting solution but it cannot run properly.It give the error again. Attached herewith test document.
Please check it and suggest the proper solution.
