I have done a topology optimization on a small component and want to do size optimization on the obtained resulted structure. So How can I export model (after removing the desired material) to hypermesh?
Hi Prateek,
Have a look at this. You can use OSSmooth to get the optimized model or as CAD format in HyperMesh
Hi Prateek, Have a look at this. You can use OSSmooth to get the optimized model or as CAD format in HyperMesh
hey Prakash thanks for the help. one more problem is there when I do size optimization of a simple plate there no error came and the result is clearly in hyperview. but when I do perform the same thing on a different structure it is not showing the result. Here I'm sending the '.hm' file of my problem. can you please see n tell me where I had done wrong.
I see results.
The thickness is reduced to almost 7 units from 15.
