Hi everyone,
I used law36 to analyze my models. Elements are failed base on plastic strain criterion.
When I set l_thick = 1 (thickness change is taken into account) in shell property, elements are failed earlier.
What is the reason?
Thanks you!
check for initial penetrations and the values in the material card X/Y scale factor for the stress strain curve..happened to me before
