Linear buckling analysis with linearly variable axial loading
User: "Altair Forum User"
Updated by Altair Forum User
Greetings,
I would like to calculate the critical buckling load Fkrit of a linear buckling analysis with the following linearly varying axial distributed load.
The starting load is Fo= 0,1 N which increased ends fixed in a wall after a range of 1000 Elements at F1=100 N.
<?xml version="1.0" encoding="UTF-8"?>post-39160-0-52864500-1440207839_thumb.p
The geometric profile is a thin-walled cross-section with a length of 1000mm.
Hypermesh says the result of the lowest eigenvalue takes lambdacr = 7.288 e-03
The critical buckling load PCr is defined as:
PCr = lambdacr * Pref
For a static case corresponds the force magnitude of one Force the Pref value. (As shown in the tutorial linear buckling analysis)
I have two questions:
1. What would be the best way to implement the linearly variable axial load as equation? I mean distribute the force circumference or use rigids?
2. How can i determine the value of the Pref for a linearly varying axial distributed load?
The analytical solution for PCr is something about 185 N.
Thanks in advance
1 - 2 of 21
