I'm trying to model a rocket stand and achieve a natural frequency of 80. Ive been using HyperBeam to similate the cross sectional areas of the bars, however every time i try it gives me the following error. It was working before I put the cross sectional areas on there is it maybe because the L cross section doesnt exist normally in Obtistruct testing or is there some other reason? I tried renumbering the nodes however that did not work.
*** See next message about line 769 from file:
C:/Users/Niki/Documents/UTEP/cSETR/HyperMesh/tower design 3.fem
'PBARL 17 1 +'
*** ERROR # 1479 *** in the input data:
Incorrectly formatted numeric data in field 9.
(If it is a character field, it should start with a letter.)
*** Run terminated because of error(s) in the input data.
