Hi George,
Thanks for you all helps.
I want to have such as attached pressure distribution on the cylindrical shell in Hypermesh with Radioss solver, can I?if yes, how?
I always appreciate your help.
Best,
sara
Hi Sara,
You can apply pressure load on the cylindrical surface. Create a contact surface (Analysis>>contactsurfs) and apply the pressure load on the same.
Create a Pressure vs Time function and recall the same while defining the load.
