I have started applying AMS in RADIOSS v14.0 .Initially the simulation is running and after some time (around 2 hours). Later an error is sprouting .Pl see the below error message.
** ERROR : AMS IS LIKELY DIVERGING:
... RUNNING DIAGNOSIS
** INFO : COULD NOT IDENTIFY THE ISSUE.
Can you suggest a possible soultion to curb this? The values recorded in .OUT file are normal. in the sense there is no abnormalities in %energy error or mass error%. However it suprises me that after almost half of the simulation is done with AMS,divergence happens.
I have converted the same input files(Starter and Engine files,) into v13.0 and run in RADIOSS v13.0. The simulation is running with no error. I am using a time step of 5microseconds for the simulation. I have laso tried with smaller and larger time steps just in case to verify if it is because of DTMIN value. But the scenario is same even with that case.
I have also gone through the release notes for v14.0 . It has included some relevant points while using INTER7 and INTER2 which I have taken care.
Thanks for your support in advance.
