What is relation between CGAPS and Contact conduction?
Hello friends,
I have implemented contact Interface between Hexa and tetra mesh with contact surface, and also using CONT Properties with PCONTHA activate and value also put in KC = 1000000, now In my model I have also introduced CGAPS which is not in contact area, just defined CGAPS for mechanical friction and for mechanical Analysis, but because of CGAPS I can't get right thermal results. without CGAPS I got right thermal means temperature field.
I am curious to want to know how CGAPS affects on my contact Interface and contact Card?
Make on Notice: where I have applied CGAPS there not any thermal Transfer or contact thermal Transfer. so may be not Need to apply PCONTHT Card.
Thank you,
Jay
Hello Rahul, yesterday I have send one another file with One more component with CGAPS. As in your model I wnat to implement like around your Pipes or geometry one hollow circular pipe and inbetween there is CGAPS; by assuming the inside geometry is moving. The main question is CGAPS I have used for mechanical Friction or mechanical load step, but it affects also in my Thermal load step. Temperature goes up. And it affects Mechanical stresses too. Make sure I am doing Thermo-Mechanical analsis so Temperature which I got from Thermal load step I have to use in Mechanical load step. which I have already mentioned. Please correct my Problem.
0 -
Apply thermal contact via PCONT instead of creating CGAP elements.Also without checking your orignal file it would be difficult to comment.
0 -
I am using Contact-based Thermal Analysis, so I have already used PCONT in my model, CGAPS are not where I have defined contact conduction or Contact Interface. Still I can't understand how It affected my temperature results. CGAPS use for friction I have already send you Pictures.
I hope you can undertand my Problem.
0 -
I got your problem.I will check internally & update you soon.
0 -
Also if it possible to share screenshot of Temp output/PCONT/CGAP parameter then please do share.
0 -
Please make sure to use PGAPHT which is required for CGAPG in thermal analysis.Also naming which you have used as CGAPS confuses me.I took it as CGAPG.
0 -
Hi Rahul, I got solution of my problem. I have to put value inside the PGAPTH, the value of Lemda. In PGAPHT thermal based Contact case I have to fill KAHT = almost zero. CGAPS I am using for mechanical case but when we use couple Analysis then We should also add PGAPHT activate and put Zero in KAHT.
Thank you for your Support.
Thank you.
0 -
Thanks for the update.
