I am doing a crash simulation using RADIOSS.
I would like to get the Kinetic Energy of the entire component as a graph vs time.
How do I get this?
Hi Bongirs,
Create an output block (Analysis > Output Block) for the component in RADIOSS which will create a time history file (T01 file). The output of the time history file contains variables such as internal energy, kinetic energy...etc.
Thanks George!
I will take a look and get back if there is any difficulty.
Hi George,
We are using HW 13 and during individual kinetic energy plots we get values as zero . Is there any problem with 13 version.
Hi Gopal,
Can you check the same in HW 14 version and update. If you find the same issue in 14.0, please send the files (input files and T01 file).
