How do I create a template to extract responses for nodes in HyperGraph?
For example, I'm doing a frf on a 17-node model and I want to get the magnitude-and-phase response separated by columns and by nodes from all nodes, how do I create a pattern to just run it without having to extract the answer node by node? For models with more elements this takes a lot of time.
Thanks, but in fact it would be in the HyperGraph part of my doubt. When I have a 17-node model, the FRF response in HyperGraph is divided by nodes, so I have 17 answers and I have to save one by one because if I select all to export to csv file it stays one underneath the other and I would like they were in columns so I could extract the data I need more easily. And I also wish they could be saved at once but in different files, as if I were creating a code to extract each response from each node, but all at once.
Can you please elaborate on your query?.
If you are looking for magnitude and phase response for each node in a text file, you need to create 17 output request for 17 nodes and 17 sets which contains each node with OPTI as format and form as BOTH.
