Hi comrades,
   	I am simulating AC magnetic inside a cabinet which I wish to use thin metal sheet to model it. In this scenario,  the cabinet is connected to PE wire, which can be modelled by either a solid metal conductor or a non-meshed, composite and open ended coil. The physics check gives me various errors such as 'unable to determine the formulation', etc. In a word, if I replace the thin sheet model with a solid metal for the cabinet, the problem vanishes. However, I d like to know how to use the thin sheet metal in Flux 3D.
   	Is it allowed to connect thin sheet metal to a coil conductor and couple it with circuit components?
   	ken
