I am doing a study inflating an airbag with a particular shape and there are a lot of contacts between surfaces, that I modeled with interface type 7. I have some troubles because there are some nodes that pass through master surfaces (even if the interface is activated) but then the contact is applied and the nodes can not pass through, creating high contact forces and reducing the time step. I wanted to use the control card DT/INT/DEL to delete the interface in those nodes, I fixed Tscale to 0.9 and Tmin to 1.0 e-4. When I run radioss, time step reduces up to 5e-5, some nodes are deleted but not those that passed through surfaces and have high contact forces. Any idea about how can I deactivate interfaces in nodes where the contact force is higher than a fixed value?
Thank you
