What is difference between RBEs and CE_STRUCT in Hypermesh. Can I use RBE3 instead of CE_STRUCT ?
Hi Jigar,
Can you provide the source of CE_Struct?
What is the purpose for using RBE3?
In analysis panel under equations you get CE_STRUCT under load types option.
Now I have contacts between several components under my assembly. My job is rested on a fixture.I will be importing my meshed model into Ansys APDL. For defining contacts I am confused between rbes & cestruct.
Jigar,
Are you modelling Ansys deck?
I don't see any CE_STRUCT in OptiStruct under analysis>>Equations>>LoadType. See the attached image.
If your question is based on Ansys solver, I suggest you to contact Ansys support instead.
Jigar, Are you modelling Ansys deck? I don't see any CE_STRUCT in OptiStruct under analysis>>Equations>>LoadType. See the attached image. If your question is based on Ansys solver, I suggest you to contact Ansys support instead. <?xml version="1.0" encoding="UTF-8"?>
Yes i am working under ansys solver..But the question remains same. Difference between RBEs and CE_STRUCT? Can I use RBE3 instead of CE_STRUCT ?
Please get in touch with Ansys support regarding the same.
Jigar, Please get in touch with Ansys support regarding the same.
Okay!! Thank you!!
