Variable Loading (Nastran Interface)
Altair Forum User
Altair Forum User
Sir,
     I have a crankshaft on which i need to apply combustion load which changes with angle/time. How do I apply in Hypermesh to solve the problem in Nastran.
I have values of forces for each 30 degrees of crank angle. Please help me with this problem
Thanks and regards,
Pratik
  • Altair Forum User
    Altair Forum User
    edited April 2015
    Dear Pratik,
          Create DAREA load collector of required load amplitude at the node of interest, Import normalized load versus time data using TABLED1. Then reference DAREA & TABLED1 in TLOAD1. In this way time dependent load can be applied.
    Regards
    Ramsubramanian
  • Altair Forum User
    Altair Forum User
    edited April 2015
    Hi Pratik,
    You can make use of Equation option in Force/pressure panel to create variable load.
    Please Note: If you are a commercial customer, you can contact your local support http://www.altairhyp...ortProduct.aspx
Welcome!
Welcome!
