I am doing an analysis of louver fin radiator but my results are not matching with experiment.
Boundary conditions are,
air flow = velocity inlet(5.58 m/s), pressure outlet and inlet temp (293.3 K)
water flow = flow rate inlet(120 l/m), pressure outlet & inlet temp (353 K)
cfd result expt result
air outlet - 349.62K 327.43 K
water outlet- 352.68 K 347.14 K
i tried to attach .acs file but its failed.
send me dropbox link i will attach file.
Thanks in advance
Regards
Ravi H
Have you tried compressing the database file? TRy uploading after using this.
http://www.altairuniversity.com/2014/02/04/option-to-compress-acuconsole-database-while-closing-it/
On the the hand it might require detailed investigation, that might not be feasible via forum. Have you contacted your local HyperWorks Support ?
http://www.altairhyperworks.com/ClientCenterHWSupportProduct.aspx
