Can someone help me with the following error?
*** INTERNAL PROGRAMMING ERROR *** in file 'datasetFtoC.c', at location # 345.
Hi @mramakri
What type of analysis are you doing?
Is it possible to share the model file?
Please use the file transfer link in my signature to share the model file
Hi Prakash Pagadala,
I have sent you the model file.
Can you remove DTI_UNITS, OUTPUT and global case control cards from your model file and run the analysis?
Thank you for your help. It works.
I also got internal programming error but with different message.
*** INTERNAL PROGRAMMING ERROR *** in file 'sparsekit', at location # 1952. ioerr(1) = 0 **** ABORTING RUN DUE TO AN INTERNAL ERROR ****
I have attached .out file, can anyone here help me out please
