MultiPhase Simulation of Pump
Updated by Altair Forum User
Hi All,
We are trying to simulate the fluid flow through pump using AcuSolve Multiphase simulation capabilities.
Using Sliding Mesh approach, fluid does not enter into the rotating interface zone.
Where in case of MRF approach, we are facing convergence issues even for small deltaT.
1 - 3 of
31
Hi Pradeep,
As discussed over the phone, we shall get back to you on this query.
Thanks.
Kamlesh
Hi Pradeep,
We are running the case at our end. Once completed I will let you know our observation.
Regards
Abinash
Would it be possible to upload the .inp files? and a screenshot of the geometry. If fluid is not entering the interface surface, it probably means some issue with assigning 'boundary condition' or interface surface.
