Hello all,
I have done static analysis of the structure using static load case of 971N. I have applied Fully reversible sinusoidal curve (100 cycles) for fatigue analysis in optistruct. SN curve is calculated in optistruct using UTS. After analysis i am getting minimum number of cycle as 1.581e-2 which seems unrealistic.
What can be the problem?
