Hello everybody,
I have a question relating to the contact of two surfaces. I’m setting up a topology optimization of a wheel carrier (see the picture below). The model consists of several connections which are merged to my non-designspace (red). Two bearings (green) apply all occurring forces to two bearing shells which are part of the non-designspace as well.
I already created contact surfaces and interfaces using CONTACT - SLIDE as type. As soon as I try to run the optimization I receive the following error message (AUTOSPC is turned off):
*** ERROR # 2133 ***
There are d.o.f.s that must be constrained, see the above table.
the number of d.o.f. = 19295
What do I have to change to run the optimization successfully?
Thanks in advance,
Pano
