I am currenlty trying to use the "getBinnedProperty", but I am recieving the following error message
"ValueError: setting an array element with a sequence. The requested array has an inhomogeneous shape after 3 dimensions. The detected shape was (5, 5, 5) + inhomogeneous part."
This happens for all choices of numX,numY and numZ, except 1. The code I used was
"deck.timestep[1].particle[1].getBinnedProperty(numX,numY,numZ)" where I tried to vary numX-Z. The deck is correctly imported, and the timestep as well as particle also is correct.
Any ideas what might cause this problem?
