Hi, I'm having a bit of problem with free edges using 2d meshing, is there another way to get rid of them apart from using equivalence because that is not working at the moment. I've attached a figure below.
Rossay,
Seems to be like, this is connectivity issue. You can share your model file with us through our drop-box. we will look into it & suggest you the respective changes.
@Praniket Hi thanks for your swift response, I also would like to get the pressure distribution over the model from Acufieldview after I've solved it in VWT how would export these pressure back into hypermesh on the model for optimisation?
