I have a problem with the virtual wind tunnel. When I do the test it works perfectly but at 80% it does not progress and it closes the hw.exe. At that point you should open Acufieldview to make the captures that will be exported in the PDF. But the essay stays there and does not export the PDF. If I look in the folder Run Patch the test is finished but without the PDF. In the folder I can find all the results of the coefficients but not the PDF. Would anyone know how to solve this problem? I attach files to explain better. Thanks for your help.
