Hallo Guys,
i have a part with TETRA 1st oreder element optimized the running was quick (20 min) simulation time and it needed low memory, where i have used default value.
However i have changed the Element to 2ed Order TETRA to have better results. but the simulation does not run or maybe tooks to long i get a massage with :
The amount of memory allocated for the run is 648 MB.
This run will use minimum core processing in the solver.
What to do????
Thanks in advance
