dear all,
I did a 2D composite analysis on a member exactly following the procedure given in this link http://www.altairuniversity.com/analysis/structural/composites/modeling-and-analysis-of-composite-structure/
but the failure index values are zero in the output
kindly check
Hi Nitish,
This is because you did not select a failure theory to calculate failure indices.
Card Edit Property>> FT>> Select the failure theory which you would like to use.
thank you very much sir... i got the solution
