Model correlation
Altair Forum User
Altair Forum User
I would like to compare the modal deformations of an experimenral model and a numeric model. For this, I use the option Model Correlation of the NVH. I load the experimental results issued from LMS (.unv) as a reference file. The correlation file is an .h3d (normal modes analysis). The first attached image shows the screen  after Load. The next step is to choose the node pairs, I did Scan. The second image shows the screen after Apply. Firstly, I am not sure that this result is correct. Secondly, HV gives an error message and shuts off while clicking on MAC.
How can I solve the issue ?
Thank you.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited November 2020
    Hi Alina,
    Please refer attached document which covers video & pdf of model correlation.
  • Altair Forum User
    Altair Forum User
    edited March 2017
    Hi, Rahul,
    thank you for this information, it will be  very useful.
    I've found why I had such a huge deformation on the second image, it is due to the error in the .unv file. It was corrceted. However, I still have this problem of shutting off of the HyperView while trying to get a MAC. I loaded 2 same .unv files, so normally it should give a MAC perfectly diagonal, but HV refuses to give a MAC. Do you think it may come from the errors in unv file? It works well when I do the same thing with 2 identical h3d files.
  • Altair Forum User
    Altair Forum User
    edited April 2017
    Hi @Alina
    Does the same happen when you use a .unv and .h3d file?
    Does both the .unv files has mesh of the structure?
    Can you please check this?
  • Altair Forum User
    Altair Forum User
    edited April 2017
    It works, it was an error in  my .unv file. The error was rather difficult to find, i had 2 times the node N1 in each set.
    Thank you for you replies.
