Open AcuSolve Command prompt and use çd'to change directory to workshop3 directory
-> acuProj -crd ../Workshop4/MESH.DIR/blower2.crd
can you please, explain to me?
There is an easier method to do the projection of solution from old case to new.
Use AcuConsole : Tools > Project Solution > select the Log file.
Further it will ask for which variables should be projected.
