hello all,
Can I simulate a submarine pipeline subjected to underwater shock by Hypercrash ?
I need a pipe hm file where can I find it?
Best regards,
Sara
Hi Sara,
I recommend you to create the geometry in HyperMesh where you can easily create pipe like structures.
We have a RD-T: 3520: Pre-processing for Pipes Impact tutorial in Help and I have attached the same file where you can get the pipe geometry.
Dear George,
I cannot find the tutorial and also I cannot open the attached file. would you please sent me the tutorial?
I really appreciate your help and time.
Best Regards,
Hi George,
I am so sorry that I take your time.
I found it.
Thanks again.
Best,
can I simulate a flow over the pipes and an internal flow inside the pipes by Hypermesh and solve it by Radioss?
You can have a try modelling water with SPH elements and solving with RADIOSS.
But I feel Acusolve, the CFD solver of Altair, is better suited for this need. We have a similar tutorial. https://altairuniversity.com/wp-content/uploads/2014/01/CFDacusolveflow1.pdf .
A case study is also attached: http://www.altairatc.com/india/2017/2017-technical-papers/CFD/03_CFD_Numerical Simulation and Flow Analysis of Rear Transfer Ducts Using AcuSolve_KPIT.pdf
