Hi, I have to do a thermal simulation for an adhesive with Young modulus dependent on temperature. Which card can I use?
Hi Virgiliio,
Please check /MAT/LAW73 and /MAT/LAW74 in the Help Menu which are for shell and solid elements respectively.
Thanks for your reply. I've just tried this card but I'm not able to set the dependency of Young's moduli on temperature! I can't find it
I'll update you on this very soon. Meanwhile what analysis you are trying to perform?.
The analysis is on the behaviour of a plate with composite bonded with aluminum subject to thermal load...
Hi Virgilio,
Please check with /MAT/LAW80 in the Help Menu which provides an option to input function for temperature dependent Young modulus.
Thank you very much!
