How to Calculate torque in Acusolve.I am a beginner Kindly Help me..Help me with steps if available.
The easiest way to get torque is to have the axis of rotation at zero. e.g. if the object is rotating about Y-axis, then position the rotating object (best done in CAD software or HyperMesh).
Once AcuSolve run starts, you can this moment about Y-axis as 'Y-Moment' in AcuProbe. The same is available also as integrated text with AcuTrans or AcuOut.
