Small Strain Formulation
Hi There,
I am Simulation an AirBag with MONVOL_GAS option with CardImage PresLoadCurve Option with material Rubber and Foam.
At the start a huge ERR% is occurring (-99%). Later some elements are undergone small strain formation with
such message:
** WARNING ZERO OR NEGATIVE SUB-VOLUME : 3D-ELEMENT ID : 41274
ELEMENT IS SWITCHED TO SMALL STRAIN OPTION
Later there is a huge drop in time step ( in order of 3.0484E-67) with zero energy error and gradually time step increased and fixed at 1.1377E-06 and simulation running smoothly.
But in animation file the volume of AirBed becomes Zero with gradual increase in pressure.
Prop used:
P14Solid
ISOLID: 14 (with 12 run automatically killed due to exceeding energy error limit)
Ismstr: 0 (used 2 with DT/BRICK/CST but same effect)
Icpre: 1
Please suggest some modifications.
I would like to share model file through Secure File DropBox if needed.
Hi Pritam,
Please share the starter and engine out files.
0 -
Dear George,
I shared the file.
Please review and suggest.
Thanking You.
0 -
Hi Pritam,
Received the files. Which unit system you are following in this model?
I doubt this error is related with the material parameters. Please check the same.
0 -
Hi George,
Unit System: mm Mpa Ton N
I tried with possible alternative options with the material models as per my knowledge.
But couldn't figure out the error.
So seeking for your help.
thanking you.
0 -
Hi Pritam,
This is clearly an issue with the material parameters. I just varied the material curve with the one in the Help Menu of /MAT/LAW69 and the same ran without any issues.
I strongly recommend to recheck the rubber material parameters.
0 -
Hi george,
The model is running properly without any error
Thanks for your suggestion and support.
Thanking You.
