Script to change report template Layer name
I would like to create a script that helps me to set the name of layer created by report template to be the same as my curve name. Does anybody knows if such a script already exist or maybe somebody knows how to implement it in Hyper Graph? Thanks in advance.
Piotr
what is layer, sir?
0 -
Hello Tinh,
Layer can be found in 'Report Templates'. I have attached picture to show an example. I have a set of curves with name 'test_curve' that had been read in using a template. Thanks to that I am able for example to hide all curves that belongs to this layer. What I would like to have is a short script that will change the name of the layers according to the curve name (now it is Layer1 for test_curve). Usually it can be changed by hand, but if you have read in 100 curves then it is not efficient to do it manually. Maybe such a script already exist? Thank you for your help.
With best regards,
Piotr
