How to open '.bc_warnings'. As every time while giving run, it is asking to check this file before moving further.
Regards
Rajendra
BorgWarner
Hi Rajendra,
You can open the .bc_warning in a text editor. Can u send us the warning file for review and comment.
You can go ahead with the warning and run the simulation. It wont hamper the solution.
Please send the warning file to support@india.altair.com .
Abinash
I have open it. It is written that:
*** WARNING: Surface 133715 of element BC 'Int_BaffleInletSide_CircularTube_Side0 tri3 CorrugatedTube_1 tet4' is in the interior
This surface share two component. And I have defined it as default wall.
Is it correct or wrong.
