I am attempting to optimize an imported geometry though I ran into several problems;
- The mesh quality was apparently lacking (used the tetra mesh option to mesh create it), so I bypassed this check by using a control card.
- Though point loads and contraints have been applied to the mesh, the output is only of a few iterations and too closely resembles the geometry to be called a viable optimization: reducing the upper bound of the optimization constraints does not appear to resolve this...
As a side note, I would also like to know if it would be possible to implement moments onto the mesh. I have a general idea but I'm not entirely sure.
I will attach supplementary files as soon as I am able.
Thanks
Edit: I would also like to mention my goal is to minimise compliance with a volumefraction or mass fraction as an optimization constraint.
Edit2: Nevermind I solved my own problem.
