PROBLEM: Composite Optimisation
User: "Altair Forum User"
Updated by Altair Forum User
I am trying to do the second phase of the composite optimisation process - the sizing part.
However, I get the following error : 'invalid design parameters for w.r.t'
I realise that if I change my laminate properties from 'Smear' to 'Total' it works. However, I am not sure if this is correct.
Also, if I add a buckling load, neither of these work.
Can you help me? it is urgent.
I have attached the FEM file with the issue
Best Regards,
1 - 11 of 111
    OP
    Hi Rowan,
    I think the problem is coming from the buckling constraint. Since you have a upper bound of 1, solver will try to remove all the material and this makes the thickness of the laminate to zero.
    Try to add a minimum laminate thickness constraint and check if you are able to avoid the error.
    OP
    Thanks for your reply. Even when I put the buckling constraint as lower bound as 1 instead of upper, it gives me the same error. If i add a shear strain constraint, the error does not appear anymore but the shear stress is not fullfilled.
    OP
    Rowan,
    Can you use a bound value close to the results?
    OP
    Rowan,
    also, try to give a manufacturable thickness to the plies and a laminate thickness constraint to the laminate so that the thickness cannot go to zero.
    OP
    Hi Prakash,
    I've got the same problem and I can't manage to solve it... I've shared the .fem file in your Dropbox.
    Hope you can help me! It is urgent.
    Thank you!
    OP
    Hi Mcorsa,
    I don't have access to dropbox link.
    Please share the .fem file here or through personal message
    OP
    Since I am using HW 12.0 here, after deleting the Freesize desvar in design variables optimization started.
    OP
    FYI,
    You get that error because the laminate thickness is going to zero. Provide a minimum laminate thickness constraint on the design.
    OP
    Yes, I've provided a minimum laminate thickness contraint of 0.2mm in the Freesize desvar (picture) and I've updated it as composite size desvar
    But if I have to delete this Freesize desvar, how I set the laminate thickness constraint?
    OP
    In 14.0 it should be fine.
    Since I am using 12.0 I have to delete and update using composite size panel.
