Hi
how to create a rigid body with 3d volume like this picture ?
help please
thanks
Hi Fily,
You can mount rigid elements to make it rigid.
i don't understand how to mount rigid elements to make it rigid
can you explain me please
You insert for elastic modulus too high :-) It can be rigid body.
For example steel's elastic modulus 2.1e+5. If you can 2.1e+25 it can be too rigid
My comments and suggestions is based on the assumption that you are using Radioss solver for RBody:
1.Create Rbody using 1d : Rigids:Multiple nodes with calculate node.(masternode should not e connected to any existing node in the component)
2.Avoid dependency(two dependent nodes should not mate in one region)
let me know if it helps.
Regards
Rahul R
You can model a Rbody (as Rahul R) suggested inside the cylinder.
@ no_frost: Increasing E value for an explicit is not at all recommended as it may change the time step and also affects the results. This procedure may valid for a linear static analysis.
thanks all
