HI,
I am unable to get sort out this error.
Please suggest the solution.
Hi Tushar
Disable the analysis flag (Analysis>>Control Cards>>Analysis Flags) and try running the same.
As per your suggestion, run the analysis.
Now it gives another error regarding element definition or property type.
I checked properties for all elements, but unable to sort out the error.
H/w attached the screenshot of error.
Suggest the solution.
Hi Tushar,
Due to wrongly assigned property cards to components RADIOSS throws this error. Please update the components with the correct property cards.
Thanks very much.
Now it is running.
