Dear All,
how to apply rotational velocity to any component
and if possible please revert with loading conditions necessary for below analysis.
You can try creating an imposed displacement load for this case and choose the relevant rotation axis (XX,YY or ZZ). Create a rigid for the inner ring and impose this load on to the master node.
Dear George,
Thanks for supporting every time.
I have one query about assigning angular velocity to shaft. my shaft speed is 4500 rpm.
4500RPM=75RPS=471 rad/sec
Time required to complete one rotation= 0.01333 sec
1Revolution=360 degree=6.28 rad
If i want to complete 3 rotations
Time required = 0.01333x3=0.04 sec
Shaft need to complete 3 rotations in 0.04 sec.
3 rotations = 6.28x3= 18.84 radians.
X Y
0 0
0.04 18.84
Is this conditions of curve is right?
If yes, then i have done one simulation using same conditions but shaft is rotation by small portion only. Not even half rotation.
Attached is the animation file of above curve.
Please do the needful.
Thanks,
Ganesh Munge
NRB Bearings,Mumbai
Hi @Ganesh Munge
Isn't that curve linearly increases velocity?
If your shaft speeds start at time zero, try 0, 18.84 and 0.04, 18.84
