Hi all,
In my simulation model, I use the Rbe3 element to connect a temp node to a shell mesh. The Force is adding on this temp node.
I can check the displacement of this temp node with id in hyperview. Now I would like to define the displacement of this temp node as response in hyperstudy, but it does not work. I could only choose grid nodes. Anybody has ideas?
